Hide System Extension option no longer visible
pmetals
We are having the issue where if someone calls and gets voicemail and mashes the * key it is going to the 'Operator'. I would like to send that to an IVR or Ring Group instead but only see extensions in the options. Is there a way to set that up to go to a ring group?
v20-Dial '0' no longer working
Hi that option is designed just for user extensions. You may set the system extension in the forwarding rules in case the user is not registered, busy, or using a different profile status.
DanDe
