Hotel Module in 3CX Hosted
Frank86
Is the hotel module available in the cloud version of 3CX (hosted by 3CX, not self-hosted)?
Probably yes, but you can't really use it as hotel modules are usually using private local IPs.
Using this in the cloud would require a VPN, and Hosted doesn't allow that.
Reactions: OlegR_3CX
Hi there.
Hotel module option is there, however, as mentioned by @ConceptsWeb we only support the use of local IP. It is not that it won't work if you specify public IP, however this is not something we will support if you face an issue.
hey all
please if you can help me with PMS integration with Fidelio how i can get all information about i have client
What kind of information you are after?
how i can setup Fidelio with 3cx full configuration
also which website we can register with fidelio PMS system i already enable PMS in 3CX
Have you checked this guide here where you can see what is available on the 3CX end for the integration?
Have you checked this guide here? If it does not answer your request, please describe in more details as the description is not clear.
Reactions: Charles_3CX
amazingbv
