Hi Paulo,Hello Scott EIT,
Do you mean that the account/extension does follow the system schedule in forwarding?
Where in that case the user would be in 'DND' status, when the system is in 'out of office hours'.
Or is it differend?
Paulo
no that will not work, in the DND status the extension will never ring.
You whould disable the out of office option (going to DND).
Paulo
There is a work-around (not fully supported, but works great).
The function that will activate the DND is:
admin -> System -> Options -> Scheduler -> "When office is closed switch to "
This is normally set to 'DND'
What you would like to have here is 'Custom 1', but you can not select it here.
Work around to get it working:
admin -> System -> Advanced -> Parameters -> (find parameter): PROFILE_DND
Set this Parameter to: Custom 1
In this case the 'Out of office' will move the extention to the status 'Custom 1'
This status 'Custom 1' the extension will ring for a set number of seconds, just like 'Available'.
You can set diffrend option for internal and external calls.
Hope this helps you.
( And NO, it wasn't me who told you about this, I will deny any research)
Paulo
Hi Paulo,
As far as I know, the global 3CX parameter PROFILE_DND exists on every current 3CX system - whether it's an upgrade from v18 or a newly installed 3CX v20 from version U5 onwards.In this case the 'Out of office' will move the extention to the status 'Custom 1'
If I understand you correctly, this should not be an issue. Is the User using "This extension uses default office hours"? If so, the calls will be routed based on your department office hours. You will need to select "This extension uses specific office hours" under the user.Sorry, I don't think my colleague has explained properly what we're looking for here. Maybe a bit lost in translation.
We have a client who would like to be able to call an extension directly from an external number while the department is closed. Is this possible or not? It's possible when the digital receptionist message is playing by inputing the extension number during office hours but doesn't appear to be the case out of office hours. Is there a workaround?
Founded in 2005, when VoIP was an emerging technology, 3CX has gone on to establish itself as a global leader in business communications.
