How to pickup a certain call in queue with phone code?
Cozas
Forum User
We have a number of call queues set and would like to make it so an agent can pick up any call in the queue. I would like to do that with using a phone code. I know that 20ext# will pickup a call on that specific extension, but if there is more than one call in the queue it will automatically pickup the first one in line.
How can I pickup any call, let's say 3rd or 4th in line? Can it be done with a phone code?
Thank you for answers!
Hi Cozas
You can do this via the Web Client by right-clicking the call you want and selecting pick up.
So a webclient can display the queues and has call pickup like that enabled?
I guess that cannot be done via phone code?
Correct, it cannot be done selectively via code, just like you described in your initial post.
The Web Client will show you all your queues you are a member of, you can select the queue, and see all calls and pick the specific one you want i.e an important customer that you must answer immediately.
hughesdouglas
