How to synchronise multiple contacts to 3CX at once ?
andrewbirrell
Hi All,
I have implemented CRM Integration which works fine for single call sync when new call comes. But I want to synchronise multiple contacts from my portal to the 3CX at once. Is there any API interface available in the 3CX portal which provides functionality for syncing multiple contacts at once ?
Please help.
Hello @andrewbirrell,
Unfortunately there is no way to synchronize all contacts at once. The synchronization happens when the customer calls you, or you call them.
Hi @edossantos
Is there any chance this kind of feature will be available in near future ? or any developments in progress regarding that ?
I don't think so. There is nothing being developed regarding this. But you can suggest this in the ideas section.
costionofrei
