Solved i cant dial other countries
Arne Larsen
New User
every time i dial 0046 og numbers from denmark to sweeden og usa, it only sees 004 as a local number?
Where is it wrong.
i have a sip trunk.
Hi Arne,
What is your local extension range on the PBX ? Check here.
Also take a look and make sure you have an outbound rule setup in the PBX and that you have this country allowed in the "allowed country codes" found under Settings >> Security in the PBX.
https://www.3cx.com/docs/manual/sip-trunks/
Lokal 000 to 999
All countries are on
And do you have an outbound rule for numbers starting with 0046 ? make a rule which is specific and if this still does not work I would suggest getting VERBOSE logging on it and seeing why the number is calling local. If you have 3 and not 4 digit extensions this should not be an issue.
https://www.3cx.com/docs/collecting-logs-for-3cx-support/
06/18/2018 1:09:26 PM - [Flow] Target endpoint for +18454709070 can not be built!
Is One Off them
It works now, THX
Herm77
