In Or Out Of Office - DNS
DrainBamaged
Forum User
Good Day,
How does the 3CX Softphone determine which DNS FQDN to use between the "In Office" and "Out of Office" choices under "Configure Accounts?"
We use a split-tunnel VPN solution. User Internet traffic goes out through their normal connection, while business traffic goes down the VPN tunnel to our servers. However, when we have the VPN active, we are seeing softphones unable to connect and port 5090 aged-out traffic on the firewall. 5090 should only be used when the softphone is out of office, so it looks like the softphone thinks its out of office when that traffic should be going down the VPN link direct to the phone server.
Split tunnel VPN comes to our internal DNS so 5090 should not be touched at all in my mind. Understanding how 3CX determines which to use would be helpful in fault finding this.
Thanks.
My understanding is if it can't reach/resolve the internal server then it tries the external.
Reactions: Saqqara
Yes, that's how I understood it as well and that's the way we set up the VPN tunnel, but how does it reach out to make that connection? Port 53, I presumed, but would like confirmation.
Cheers.
Guess it tries to ping the ip / dns address for local first.
Reactions: DrainBamaged
Thanks Saqqara, but I'm trying not to guess. I need to understand this process so we can fault find it.
Can I get an official word on how the 3CX softphone determines if it is in or out of office please? Does it use ICMP or DNS to test for a connection? IP or FQDN? Or is it some other mechanism. Cheers.
Wireshark will help you here
Wecare_ITA
