inbound direct sip is rejected
mathiasx
i configured the 3cx server with an voip provider... that is working fine.
Now i wanted to allow incoming direct sip calls from anyone in the world ;-)
I set in "general settings" the "Allow calls to external SIP URIs" to checked and in "Local SIP domain" i wrote our server name (sip.mydom.net).
Outbound direct sip is working fine.
Inbound direct sip to for ex. [email protected] is rejected with the following message in the server log:
[CM010001] Line configuration does not allow identification of the source of this call. Check Advanced Options for Gateways and Providers and match a field to a correct value from the following: Contact IP: '91.151.x.x'; From: '857681'; To: '1022'; Rline: '1022'; Contact: '857681'
So the message is right... there is no voip line for that contact and i don't want one because i will allow anyone to call me ;-)
Any idea whats missing in my config?
Regards, Mathias
So... anyone else have an idea how to fix the direct SIP problem?
I have put the PBX direct connect to internet (NO NAT), the direct SIP also not works. I think may be next or next next version can be solved this issue.
so... anyone from 3cx reading this???
is it a bug?
so i don
It might be a bug (see the word might).
it is something that needs to be tested in the lab. You will have the same problem when you configure call forward on the phone (not using the call forward button).
My take on this is that, yes there might be a bug in the direct sip to sip, not only that it might try to use the same ports for both the initiator and terminator, this will clash.
If you can (if you have purchased the version) log it as a bug/issue and 3cx will look at it.
I think it is a bug or a non documented feature :-).
For what it is worth, i cannot get it to work either. :oops:
no one from 3cx read this :?: :?: :?:
:oops:
System should have an extension with SIP ID = 1022 to process your call. Just put '1022' into 'SIP ID' field of 'Other options' of an extension that should receive direct SIP calls to [email protected]
Hi archie,
thanks for answer but it does not work :-(
I changed the SIP ID field to only 1022 but got the same error message (CM010001) as posted in my first post in this thread.
Regards, Mathias
Make sure that in the 'Settings for Direct SIP Calls' you have specified 'Local SIP domain' to be exactly sip.mydom.net. It MUST match host part of To: field of incoming INVITE. Make sure that incoming INVITE has
To: <sip:[email protected]>
Hi archie,
yes it is so :!:
I checked this before and now again, it is sip.mydom.net
Regards, Mathias
FIX for direct sip call:
1. Delete all empty "sipDomain=" entries from 3CXPhoneSystem.ini file and leave only one that specifies PBX domain
2. ONLY user part of sip address must be specified in "SIP ID" field
it means if you sipid is "user@domain" you must specify only "user" in SIP ID field
Regards,
Stepan
Yeah, we just discovered small but annoying bug.
Please, open your 3CXPhoneSystem.ini file and remove all strings where sipDomain =
(I mean is empty)
Make sure that in [General] section of the file there's only one sipDomain string, exactly
sipDomain = sip.mydom.net
Hi archie and sy,
thanks for that importend info.
I'm on the road today, i will test it tomorrow.
Regards, Mathias
(I mean is empty)
OK, that is working well ;-)
Thanks for that info.
Regards, Mathias
Hi, this post is very informative; however I would like some specific information. If someone can help me then please send me a private message. Best Regards,
Graham Robertson
