Solved Incoming caller ID presentation
Waddy
All inbound calls are stripping the Leading 0 at our trunk, all I want to achieve is prefix "all inbound calls with a 0" using 3CX and cannot work it out.
I have read this https://www.3cx.com/docs/cid-reformatting/ but just dont understand it.
In simple terms we receive a call through the inbound trunk, the number should present like this 0407 123 123, our Staff see 407 123 123.
Thanks.
Scenario 2 in that guide is almost exactly what you are asking for.
Thanks but I just dont get it :(
Its all incoming numbers I want the 0 prefix.Would it be this?
Source Pattern: (.*)
Replace Pattern: 0\
Replace Pattern: 0\
Almost.
You've used brackets which indicates the first variable.
Replace Pattern: 0\1
Reactions: Waddy
Almost.
kieferschild --- Thank you! Excellent, that fixed it. It was hurting my head :)
Thanks also John S - I did the training, thanks.
Reactions: JohnS_3CX
EMMEPICASA
