Incoming rules, main number of trunk
wmeter
Just out of curiosity, if I configure a SIP trunk I provide a 'default' destination on the first tab of the trunk configuration. I also have to give the main number on this first tab. However, I also see the same number available if I create a new Incoming rule, which one takes precedence and what's best practice ? Is the destination on 'tab 1' a sort of 'wildcard / catch-all' destination ? Or is it really linked to that single DID ? And what happens if I create _also_ an inbound rule for that DID ?
The trunk rule is a catch-all so technically you only need to add inbound rules for additional DIDs. I typically will route the main number as an inbound rule just to have complete visibility of all inbound call routing.
Reactions: wmeter
It will also depend on whether you have (have paid for) actual DID service on the trunk. The DID information is sent in a different field from Caller ID, so if you do have a DID number come in, it can be routed using a rule off to a specific extension. If no DID information is sent (when main number called perhaps?) , then the call should follow the default route.
Reactions: wmeter
Hello @wmeter
If you create an Inbound rule using the main trunk number then the 2 are connected. If you do a change under the main trunk number then the Inbound rule is also affected and vice versa.
Reactions: wmeter
zipman
