Inconsistent BLF call pickup behavior: Yealink phones vs 3CX Windows App
PBX128
when a BLF key is configured in 3CX, it is synchronized to both the Yealink phone and the 3CX Windows App.
On the Yealink phone, pressing the BLF key while the monitored extension is ringing automatically performs a call pickup (internally using *20*).
In the Windows App, the same BLF key is displayed, but clicking it does nothing while the monitored extension is ringing.
As a workaround, we have to create additional pickup-specific BLF keys in the Windows App.
Is there a reason for this inconsistent behavior? If call pickup works via a standard BLF key on supported desk phones, I would expect the 3CX Windows App to behave the same way.
Thanks for your feedback.
What version of the app are you running please? If V5.5, can you run the same on 3CX Beta V5.6?
Additionally do you see the same behaviour for Webclient?
Yes, I tested with version 5.5 and there is the same behaviour in Webclient (3CX v20 U8). Unfortunately I am not able to test it with 5.6 beta at the moment.
DejanMDS
