- Joined
- Jul 25, 2024
- Messages
- 2
- Reaction score
- 1
I find it unfortunate that they removed the option, in the statistical reports, to view data on an hour-by-hour or month-by-month basis.
Looking forward to the Grafana integration! Curious, will that live on the same 3cx server or require another VM? Any talks of creating a full Recording Management UI for agents, supervisors, managers, etc? Also, I see the storage is currently set to 1 location for Backups, Recordings, etc. And the Voicemail transcription requires Google Storage. Any chance of having in future those to be separated so Google Storage could be for Transcription and Backups could be SMB/FTP/local? The Google Storage works fine, but just wondering if maybe in future could be separated? Thanks in advance. I am liking all the new features released.I think you will be happy with the Grafana integration which is planned. You will be able to schedule your reports at any time, as many times per day as you want, till your SMTP server throws the towel in!
The transcription can be done with OpenAI as well, so you dont need to rely on Google for the transcription. This will also allow you to perform an analysis of the calls as well and get a sentiment score from 1 to 5 as well as a summary.Looking forward to the Grafana integration! Curious, will that live on the same 3cx server or require another VM? Any talks of creating a full Recording Management UI for agents, supervisors, managers, etc? Also, I see the storage is currently set to 1 location for Backups, Recordings, etc. And the Voicemail transcription requires Google Storage. Any chance of having in future those to be separated so Google Storage could be for Transcription and Backups could be SMB/FTP/local? The Google Storage works fine, but just wondering if maybe in future could be separated? Thanks in advance. I am liking all the new features released.
Oh. That is great. I will setup OpenAI for the transcription and then use the local storage for backups. Thanks for that. Sounds good on the Grafana separate VM. We are ready for it. Thanks for the info!The transcription can be done with OpenAI as well, so you dont need to rely on Google for the transcription. This will also allow you to perform an analysis of the calls as well and get a sentiment score from 1 to 5 as well as a summary.
Then you can store your stuff on any storage location available, like SMB FTP etc.
It will most probably be a different server that talks to 3CX to get the information. The 3CX server should ultimately be tasked with only processing calls and not bogged down with handling the extra load of data analysis.
This is indeed a problem!EXPORT/IMPORT EXTENSIONS
It is not possible to export and import extensions in V.20 like in V.18 -- many fields are missing, for example related to SIP authentication. For example, if you need to recreate extensions for some reason, earlier was possible with export to .csv, edit the file and import back, now this option is useless -- you lose all information about IP phone, specially DECTs, etc., you need to recreate them manually and to edit DECTs, etc. This is pure nightmare, I have customers with more than 1000 extensions. The workaround is editing the backup file, but still this is not vital as solution.
Please consider bringing back this functionality in Update 4 of V.20
Windows doesn't have a direct upgrade path, one must uninstall, reinstall, restore. Or create a Debian VM and restore there (since Windows will require an Enterprise license).and Windows Server
Thanks! Wanted to be sure.Windows doesn't have a direct upgrade path, one must uninstall, reinstall, restore. Or create a Debian VM and restore there (since Windows will require an Enterprise license).
It seems to me that Grafana is paid. Unless it's included in the 3CX package?The transcription can be done with OpenAI as well, so you dont need to rely on Google for the transcription. This will also allow you to perform an analysis of the calls as well and get a sentiment score from 1 to 5 as well as a summary.
The self-hosted version is open-source.It seems to me that Grafana is paid. Unless it's included in the 3CX package?
You will be able to use a variety of services, also cloud ones, including powerBI. Or install free version of PowerbI locally we are still working on it.Oh. That is great. I will setup OpenAI for the transcription and then use the local storage for backups. Thanks for that. Sounds good on the Grafana separate VM. We are ready for it. Thanks for the info!
Why don't 3CX just re-introduce the option to set the time on each scheduled report that we had on previous versions (before v20). Creating multiple 'virtual' report users, in different time-zones, seems like a poor workaround and to achieve something that worked before. Also, what happens when Daylight Savings Time happens?It will use the timezone of the Department that the extension has its "Main department membership" set to.
Founded in 2005, when VoIP was an emerging technology, 3CX has gone on to establish itself as a global leader in business communications.
