Solved [INFO] - Inbound Rule prefix removal
Fabio Bologna
Good morning guys,
is it possible to remove the inbound rule prefix from the call? it's being displayed on the phones connected and its totally not necessary I just wanna see the number...
Thanks!
Yes, you can
3CX Management Console - Contacts - Options. Change Add Group, Queue or DID/DDI Names to Caller ID to 'do not add'
Yes, you can
Thanks!!! Solved :D
Bluebox Global
