Integration of Freshservice in 3CX
Noah Barbe
So, I created my CRM with the documentation of Freshservice and that of 3CX. Currently my CRM creates a contact for each call.
The problem is that he should only create one when the contact does not exist in Freshservice.
Then, at the end of a call, it should create a ticket, but it does not.
Thank you for your help
Noah B.
You should enable verbose logs from the 3CX Console > Dashboard > Activity Log > Settings. Then make a test call and check the 3cxSystemService.log to understand what the problem is. There you will see all the interactions between 3CX and the CRM, so you can determine what's wrong.
awan05
