- Joined
- Dec 21, 2023
- Messages
- 17
- Reaction score
- 2
Hi All,
My goal is using different ringtones to differentiate incoming internal & external calls on my Yealink T46U deskphones.
I've managed to change ringtone for internal calls and I believe external calls will be using default ringtone. However, I got a weird issue, you may refer to my scenarios below:
First Scenario
1. Caller = External Caller or Internal Caller
2. Callee = Deskphone 1 (without DID, caller called to Main Line and it is assigned to a Ring Group 1, Deskphone 1 is a member of Ring Group 1)
Result : Both External & Internal calls are using same ringtone (Failed)
Second Scenario
2. Callee = Deskphone 1 (with DID, external caller called directly to its DID, internal caller called to extention)
Result : Different Ringtones are being used for External & Internal calls (Successful)
In summary, when external callers make a call directly to DID, different ringtones are being used. However, I won't be assigning DID to every single deskphone in my office. I need help and suggestion to resolve the issue in my first scenario. I am using V20 and it is hosted on 3CX
First Scenario
Second Scenario
