iOS - 3cx app Maintaining Push Subscription through inactivity
kimurai
Gold Partner
Hello everyone,
I'm having an issue with the 3CX iOS app and push notifications. I'm running 3CX V20 and the latest iOS app.
The problem is that my push subscription expires after 7 days of inactivity. This means if I don't receive a call or open the app for a week, my phone will stop ringing. I can see a "Deleting Expired Push Subscription of extension xxxx" event in my 3cx event log.
However, I did notice that on a 2nd iPhone with multiple extensions configured in it’s 3CX app, it does not lose its push subscription even after a month of inactivity on the main active extension.
Two questions,
  • Is there a way to prevent the push subscription from expiring on my iphone without calling or opening the app?
  • Am I correct in guessing that because I have multiple accounts setup on my 2nd iphone with 3cx app, some of which are more active, that it is keeping the main account’s Push Subscription active? If it is not this, what other reason would this phone’s Push Subscription stay active while the other doesn’t?
Any insight would be appreciated. Thank you!
Is the app up to date?
If the phone reboots (or, I think, the app updates hence relaunches) it needs to be opened.
Are you toggling between the extensions in the second phone?
The push isnt account related, it is app related. If one account is more active, than all accounts will be receiving push. And no, you cant change the 7 days for inactivity.
Only one account can be active at a time.
And I thought the 7 day timeout would self refresh now, after an app update at some point?
No, you need to use the app during the 7 days... Otherwise it will loose the push.
It autorefreshes if you keep the app in the background (aka in the app switcher.) Otherwise it doesn't.
Academics Excellence Ja
