IP phone for blind people.
Anthony R
Hi everyone,
We are preparing to onboard a client that works with blind and visually impaired individuals. They have a specific accessibility requirement: they need a desk phone that provides spoken audio feedback when buttons are pressed (e.g., pressing button 5 speaks "five" aloud through the speaker or handset).
Does 3CX officially support any IP phones with a built-in "talking keypad" feature?
What are the best available options or workarounds to achieve this functionality while maintaining smooth integration with 3CX?
Thanks in advance.
Sincerely,
Anthony Rodriguez
While I've never come across a phone with (operation) speaking capability, let alone a VoIP set. That doesn't mean it doesn't exist. A google search for any model that does what you want, would be your best bet.
I feel pretty confident in saying that 3CX does not currently support a phone like that as it is a very specific feature and there are many (considered) mainstream models that not yet supported. However, just because it isn't supported, doesn't mean it won't work. The majority of sets for the visually impaired seem to be limited to large buttons, unfortunately. There might be a PC SIP application that is compatible with 3CX.
https://www.3cx.com/sip-phones/
Reactions: Anthony R
Most blind people would use something like Jaws as a screen reader.
So as long as the app is Accessibility friendly, you should be fine.
@Anthony R , with update 10 we are streamlining custom IP phone template creation and integration/maintenance. This would mean it would be easier to get a phone that has the accessibility features you want to work with 3CX in a properly integrated manner.
And if Braille on the buttons is a sufficient solution, the Fanvil X305 is a supported device.
Hi team,
I found some ip phones with android OS that could be a possibility: yealinks vp59, t58w, nevetheless, I'm wondering if with the new update 10 I will have support to make it work properly on 3CX since they are still not on the preferred IP phone list?
Best regards.
Anthony R.
Hi team,
Best regards.
Anthony R.
Hi @Anthony R using the sp10 that currently is in Alpha version the T58W template is added under the vendor tested
Any support for these models you would need to contact the vendor.
Have a good day!
Hi Alejandro,
I really appreciate for your reply. I haven't updated any of our systems to v10 since it was still in alpha version. But that's great to hear.
Kind regards.
Reactions: Alejandro_3CX
One of our Customers is using JAWS with PWA currently in 3cx version 20.0.8...
Has to be evaluated if the design overhaul in Update 9 still works.
Customer did everything by themselves. So i don't have access or can provide more informations.
But customer was happy with the possibilities to work via Braille.
So might be worth a look.
https://www.freedomsci.de/serv01.htm
Depends on you use case.
Hi team,
Unfortunately, the Yealink T58W didn't work as the customer required. We managed to get it running on 3CX, but the talking keypad feature didn't work at all.
We want to try a Cisco 8800 series phone, as it includes that feature. However, we know Ciscos aren't natively supported by 3CX. Still, this appears to be the only IP phone that has the exact feature our customer is requesting.
Has anyone in the community worked with Cisco 8800 series phones on 3CX and gotten them to work? If so, how did you set them up? Is there a generic template available for them? Any help would be greatly appreciated!
Thanks in advance.
Best,
Anthony R.
Hi @Anthony R you have to register the device manually as mentioned in this guide
Carlos - EC Mates
