Solved Issue since upgrade cp860
Brad Cann
Gday All,
Since the upgrade to 15.5sp1 we have a single cp860, that seems to stay registered for an hour or so, and then even though the dashboard shows it as registered, it is uncallable, and no calls can be made from it.
Log from my extension to cp860:
22/08/2017 15:36:41 - [CM503003]: Call(C:4563): Call to <sip:[email protected]:5060> has failed; Cause: 487 Request Cancelled/INVITE from 10.23.50.142:5060
any updates on this?
the firmware update on the phone seems to fix the issue, but for some people getting the firmware to show up inside of 3cx is another issue. you can manually do the firmware yourself to fix problem phones.
To those who are experiencing the issue please navigate to C:\ProgramData\3CX\Instance1\Data\Http\Interface\provisioning\xxxxxxxxxx\firmware_new\yealink and let me know if you see the CP860-37.81.0.10.rom file in the folder.
Let's see if the issue is the same for all
For Linux the path would be /var/lib/3cxpbx/Instance1/Data/Http/Interface/provisioning/xxxxxxxxxx/firmware_new/yealink
I have that in the folder path but still not showing up as new firmware in the update screen. I am on Windows.
Yes, the firmware is there on Linux as well.
I have the firmware in the folder on Windows. I have 2 CP860's which have been manually updated and show as up to date. I also have one CP860 that shows as up to date but is on 37.80.0.10 and has the dropouts symptoms.
I have the file CP860-38.81.0.10.rom in the directory, but the phones does not show as upgrade needed.
We have identified the issue with the firmware update on CP860 model. The issue originates from the fact that in the new Yealink provided firmware the user agent name is different than others. So this is why the management console did not identify the model. We have found a way to fix it from our side and have pushed out a new template for these phones. It should be available in your updates section for download.
For those of you that do not have the firmware already downloaded the only thing you need to do is download the new template and provision the phones with that.
For those that have already downloaded the firmware you need to perform an additional step to have the phone working. After you download the new template navigate to : C:\ProgramData\3CX\Instance1\Data\Http\Interface\provisioning\xxxxxxxx\firmware_new.
The path for linux is /var/lib/3cxpbx/Instance1/Data/Http/Interface/provisioning/xxxxxxxxxxx/firmware_new/.
Edit the firmwares.json file. Find: "Name": "Yealink CP860", and change it to: "Name": "CP860",
Save the changes and restart management console service. You should be able to upgrade your phone after this change.
Thank you all for helping identifying the issue and helping us resolve it.
Please let us know if that works for you
Confirmed that editing the firmwares.json corrects the problem.
Thank you for the feedback and glad this worked for you
Thank you so much , I also work for me.
~~~ appnaz.com ~~~
Thank you for your feedback
Ahzaz
