Jabra Headset and Chrome Webclient
alainarnold
Platinum Partner
Hi Guys
We are testing the jabra engage 75 for our customer.
I already installed jabra direct on my win 10 Notebook, jabra browser extension and jabra chrome host.
When using the normal windows softphone i can use the jabra smart sensors (pickup and hangup), but when we use the Chrome browser it doesn't work.
google chrome browser seems to be connected whe jabra direct and i can also see the headset in the webclient
Can anyone please help me out?
Regards, Alain
Hello @alainarnold !
I made it work with only Jabra Direct and the Webclient integration. No chrome extension, no jabra plugin or what.
USB to the computer. Have you searched in the base parameters ?
Reactions: alainarnold
Hi INDY_Mathieu
thx for your reply. I got a feedback from jabra...chrome extension is currently not supported. We are using the normal windows softphone again.
Regards, Alain
Reactions: FS_Mathieu
Chrome extension is not supported but 3CX Webclient is ok (without installing chrome extension) !!
gmacinit
