Local Lan change
bennuss1
I am running ver 16 which i understand you can change without having to reinstall. Where do I change it ? Under parameters and are there other parameters i need to change?
You just want to change the IP of the 3CX machine? Once you change it in the operating system, restart your system and then login to the management console. You will see a red warning on the right regarding the IP address.
Click on it and and it will bring you here:
Once the correct (or new) IP is selected, simply press OK above to confirm.
I am running linux so will probably reinstall. I dont have any phones installed yet on the system but I want to keep my fqdn that i was given by 3cx and they created the certificates. Do I have do backup anything or I can just delete and reinstall it. and how do i connect it up to use the same fqdn. Thanks
The FQDN is already tied to your key, so reinstalling with that key will automatically assign your FQDN without asking.
The certificates will also be re-issued automatically during the setup process so you don't need to do anything about that either, some of the perks of using a 3CX FQDN ;)
However, a reinstall is not really needed if the LAN IP just changed, the system is able to adapt to that as per my first post. You don't need to reinstall unless you have other reasons you think might make it necessary.
Not really linux proficient to manually change the int to static and assign an ip
I've tried this and it works - TAKE A BACKUP OF 3CX FIRST.
In this example my network range is 192.168.1.1
Code:
Nano /etc/network/interfaces
# The primary network interface
allow-hotplug eth0
iface eth0 inet dhcp
To:
auto eth0
allow-hotplug eth0
iface eth0 inet static
address 192.168.1.202
netmask 255.255.255.0
gateway 192.0.1.1
Network 192.168.1.0
Broadcast 192.168.1.254
If you need to configure DNS
Code:
Configure DNS
Nano /etc/resolv.conf
Nameserver 8.8.8.8
Nameserver 8.8.4.4
Restart network services
Code:
sudo service network restart
You may need to force the ethernet back online
Code:
ifup eth0
Check your IP set up
Code:
ifconfig eth0
Then log in to 3CX and change network adapter.
If there is an easier way to acheive this in Linux im happy for the input.
Reactions: VictorYourITGroup
Ok.Will try that. How do I set the interface to auto so if it reboots it comes up automatically.
You will only need to bring it back up manually once after the change.
Auto on is now the default in linux? My understanding is that if the network int isnt set to auto and the machine restarts it wont come up by itself
I just gave mine a reboot and the network is still there.
you could have auto eth0 in there too, i've modified the code above.
Follow up:
I believe the "allow-hotplug eth0" is doing auth eth0 by the way
I ended up having to do a new install. In the linux version there is no capability during the install to set the local ip on the box to static. It just pulls the ip that the adapter has. Also when you change the local the ip the phone provisioning ip doesnt change.
Not quite, what happens is that the Debian Linux installer automatically tries to pick up an IP and that happens pretty fast so you might not even see that step. However, as soon as you get to the first screen here
you can select the "Go Back" option, and you will now have the choice to configure your network manually
K7oR0x
