Solved Logging picked up calls
ale85bg
Hi there!
New user needing a little information/help here.
I've come across a particular situation a couple of times, and I wonder if there's a way to handle it which I might be missing.
The situation is the following:
  • Extension A calls extension B.
  • Extension B doesn't answer...
  • ...and extension C (let's assume it's just another colleague at the same office) picks up the call instead.
Is there a way to have evidence of this in the "call log"?
As far as I can see I can only find the call once, and it shows like it's been made by A to C. Extension B doesn't appear anywhere in the log.
Is this right? Am I missing something?
Thanks in advance. :)
Are you looking at call reporting or call log?
I'm actually trying to find evidence of that in the call log, but I can't find any.
I believe call reporting gives better / easier to read info. You should be able to see destination and who answered separately.
Reactions: ale85bg
Thank you, I'll have a look into that too. :)
Reactions: Lee Cramman
Hello @ale85bg
Run a general call report and you will see all legs of the call. It will show you who you called and who ended up picking up the call.
Reactions: ale85bg
Thank you so much to both of you, it worked exactly as expected! :)
Glad we could assist.
apbGroup
