Maintenance Expiry notification on Free license
Evolute IT
3CX MVP
Gold Partner
Hey guys,
I have a license key for a customer that keeps notifying him of expiry soon.
However, this is a Free license that is already on the 8SC limitation.
It's expiring the August 8th. Is it normal?
Yes. The maintenance does 'expire' and then renews. Just like the Pro trial 'expires' and then turns into STD
an 8 annual free standard does or should not send emails to renew.
As cobaltit said there are the pro trials and the paid annual keys which get warnings...
Can I DM you with the key to check?
no that is not possible in my account.
You may reach out to John of the forum to check it for you
Hi Frederick,
Does it just appear as a message in the management console?
Hi Frederick,
Yes, and I get an email also everytime it refreshes.
As per my PM you can ignore it since it will auto renew.
Since this is an older free key I cannot see additional information from my end, so best use the contact form and choose 'help for your key' for further investigation
[email protected].
