Solved Manually pull extension details from backup
Alphabetic
3CX MVP
Morning
I've managed to delete extensions after upgrading to v18 so cannot restore the backup without taking the PBX down to reinstall.
Is it possible I can recover extensions manually from the backup?
I need to know basic info and MAC addresses really. And if possible the phone ID and pws.
Hi @kieferschild,
Yes you can. If you have a backup, open the xml file in the zip file (no need to go into folders), and search the extension name. You'll see provisioning data below with a <mac> field.
Note that is only possible of the Backup file is NOT encrypted.
Hi @kieferschild,
can i pull any more info from this?
Hi @kieferschild,
There is a lot of info in there, depends what you're looking for. Take a look and check all of the fields included, it should suit your needs.
Hi @kieferschild,
I see it now.
Phew, i'm able to salvage some of this.. :D
Excellent! Glad to hear it @kieferschild. I'll close this thread then.
GP Concepts
