MCM - Extensions per department not visible (Multi Tenant)
aee3ks
New User
I'm trying to test the MCM and just installed a fresh 3CX on Prem.
I have edited the config file to include the required custom parameters.
But when I go into Department option, I do see the option to set the Extension Range for the department
Heres the V20 Version that's installed
And no further updates available
You assign the extensions to the department and thats how they're managed.
are you running
3CX Version 20, Update 2, Beta, Build 20.0.2.708, June 2024​
are you running
Info about the version is in my main thread > aswell as the ability to update to anything else not there.
Go to Parameters and search for MCM to check the value is 1.
Reactions: aee3ks
Thank you, it was set to 0.
Also in the customparam file LIMIT_PICKUP_TO_GROUP was set to 0.
But in 3CX Admin Panel description does not match the config file customparam.
Would this still be the correct option?
Yes, thats the same. You can also toggle this on from General menu.
Thank you, could you please explain "General Menu" can't seem to locate
Sorry, Admin > System > Options
Reactions: aee3ks
Amazing thank you!
Don't suppose you are aware how Phonebooks work with Multi Tenancy or Limit per Department?
At the moment the company address book is for everyone. Dept address books are in the works.
Carlos - EC Mates
