/!\ Missing monitoring Debian packages
benrg
Gold Partner
This follows my request here.
We miss terribly important Debian packages on 3CX installations :
snmpd : used to monitor the server through SNMP : CPU, memory, swap, disk usage, processes... The most common way to monitor a production server...
smartmontools : used to monitor physical disks (SMART status, bad sectors...), and as a result mandatory on a physical production server...
We absolutely need them to properly monitor our 3CX servers...
@Nick Galea, @3CX_devteam, could you then add them back into your 3CX Debian repository please ?
They are absolutely harmless, but absolutely necessary...
Thank you very much for your support & understanding !
Hi @benrg ,
They will most probably be added in an upcoming repository update.
Reactions: jed and benrg
Hi @Agathocles Prodromou, really good news, thank you very much :)
Let's then keep an eye on the upcoming repository update.
Thank you again !
Hi there,
Haven't forgotten :) The packages pushed were security updates.
The ones discussed in this topic will make their way to the main repository hopefully soon in a different update.
Reactions: benrg
Makes sense, many thanks again :)
Hi there,
I am also waiting for the same :)
Up there, we need SNMP daemon too ...
@Agathocles Prodromou, is there any update on when the snmpd package will be available in the repos?
Is there a place to subscribe to know when snmpd is available?
Thanks.
Reactions: benrg
Has anyone tested / had a look into v18 update9 and v20 beta1, do they contain snmpd and smartmontools packages ?
Did not give a try yet...
Thank you !
Thank you !
It appears smartmontools is, but snmpd is not. @benrg
Code:
apt list policy smartmontools
Listing... Done
smartmontools/bookworm 7.3-1+b1 amd64
apt list | grep "snmp"
libsnmp-base/bookworm 5.9.3+dfsg-2 all
libsnmp40/bookworm 5.9.3+dfsg-2 amd64
Just to give some news, both snmpd and smartmontools packages are now available in 3cx v18 update 9 :)
Thank you 3CX, thank you @Agathocles Prodromou !
