Solved Missing "Received during" options while setting up exception on extension
kiske01
I cannot choose the "received during" times when an exception should be triggered.
Here are the screenshots:
How can I have something different than "All hours"?
Thanks.
I have the same problem.
Is there a work around for this ?
Hi @kiske01
This feature is available for SMB machines. Refresh the browser page and check if you have a notification asking you to refresh the page one more time. Click Yes on the notification and then the SMB admin page should change, and then you will be able to add specific hours to exceptions.
Reactions: IrinaP_3CX
@kiske01
Thank you. I was asking because my client updated to V20 and the option was'nt showing.
I got an answer from an another thread where it specifies it need to be on V20 update 1.
Anyway, thank you
Reactions: TheodorosG_3CX
