mattdarnell Gold Partner Basic Certified Joined Sep 8, 2021 Messages 36 Reaction score 5 Sep 3, 2022 #1 Is there a way to provision multiple extensions on the same phone? TIA
bibi30 Forum User Advanced Certified Joined May 26, 2021 Messages 4 Reaction score 1 Sep 3, 2022 #2 Hello use the hotdesking in pro or enterprise version.
leejor Customer Joined Jan 22, 2008 Messages 16,670 Reaction score 1,658 Sep 3, 2022 #3 You would have to create a custom template, or manually provision the set. Both render the set unsupported, which means that if you have issues (submit a trouble ticket), you would have to return the set to a supported state.
JohnS_3CX Support Team Staff member 3CX Support Joined Jan 4, 2019 Messages 14,559 Reaction score 3,726 Sep 5, 2022 #4 Hi Matt, This is not supported on 3CX and we do not have any method of doing this. We only support and provision a single extension per IP phone. Reactions: Evolute IT
mattdarnell Gold Partner Basic Certified Joined Sep 8, 2021 Messages 36 Reaction score 5 Sep 6, 2022 #5 OK, thanks.
