Multiple Trunk with same provider
support_alkivi
Gold Partner
We use 3CX with a French VOIP Provider, OVH. We use multiple trunks with OVH on the same server.
We've got some errors " simultaneously sessions ". And OVH told us we have to change our SIP PORT to have unique SIP Answer port for each Trunk.
Example :
Trunk 1 : 5060
Trunk 2 : 5061
Trunk 3 : 5062
We are not talking about Destination Port (OVH) wich is always 5060 , but the answer Port on our Host.
Is it possible to do that on 3CX ? If yes, how ?
PS : We use Debian by the way.
Perhaps just try here in trunk settings
Are you using 3CX template for OVH ?
yes, we use OVH template.
And no, if you change the SIP trunk port, you change destination port. Not the answer one.
So we had answer from 3CX support and OVH as well.
We can't put more than 2 OVH trunks on the same 3CX server :(
1 - Because 3CX can't differentiate SIP port and SIP Answer port, it uses the same
2 - Because OVH can't have more than 2 trunks from same public adress with same answer port
I use Callcentric and have one SIP trunk up and running fine for a long time. Added a new sip trunk from callcentric from a separate account and when I try to route outbound calls over the 2nd trunk it gives me an authentication error in the log. Could this be the same issue?
03/19/2020 12:12:07 PM - L:85.1[Extn:200] failed to reach Line:10001>>19041234567, reason Forbidden
03/19/2020 12:12:07 PM - Call to T:Line:10001>>19041234567@[Dev:sip:[email protected]] from L:85.1[Extn:200] failed, cause: Cause: 403 Incorrect Authentication/INVITE from 204.11.192.159:5060
03/19/2020 12:12:07 PM - [CM503003]: Call(C:85): Call to <sip:[email protected]:0> has failed; Cause: 403 Incorrect Authentication/INVITE from 204.11.192.159:5060
03/19/2020 12:12:07 PM - [CM503025]: Call(C:85): Calling T:Line:10001>>19041234567@[Dev:sip:[email protected]] for L:85.1[Extn:200]
03/19/2020 12:12:07 PM - [CM503027]: Call(C:85): From: Extn:200 ("Spears" <sip:[email protected].3cx.us:0>) to T:Line:10001>>19041234567@[Dev:sip:[email protected]]
03/19/2020 12:12:07 PM - [CM503004]: Call(C:85): Route 1: from L:85.1[Extn:200] to T:Line:10001>>19041234567@[Dev:sip:[email protected]]
03/19/2020 12:12:07 PM - Line limit check: Current # of calls for line Lc:10001(@CallCentric_Spears[<sip:[email protected]:0/UDP>]) is 0; limit is 3
03/19/2020 12:12:07 PM - Call(C:85): Call from Extn:200 to 1234567 matches outbound rule 'Spears_Local'
03/19/2020 12:12:07 PM - [Flow] Call(C:85): has built target endpoint: Out#:>>Rule{Spears_Local}>>9879575 for call from L:85.1[Extn:200]
03/19/2020 12:12:07 PM - [Flow] Target endpoint for 1234567 is Out#:>>Rule{Spears_Local}>>1234567
03/19/2020 12:12:07 PM - [CM503010]: Call(C:85): Making route(s) from Extn:200 to <sip:[email protected]:0/UDP>
Anything is possible. Best to start your own thread and put the provider (callcentric) in the title. And have you talked to Callcentric to see what they say?
Thanks! Just did that actually.. And still waiting on CC to respond.
Yep, saw it and responded there.
Reactions: ajohnson443
