NEW: 3CXPhone Phone for ANDROID WITH TUNNEL 1.3.1
Please add opportunity to use default Android System Ringtones!!!
And fix the BUG when 3CX taking over the all Volume Settings on Android. For example, when 3CX is running and I listen to music, then it is imposible to turn music volume up or down. Instead of Music Volume the In-Call Volume will turn up and down.
Best regards.
Please try this
http://www.3cx.com/downloads/3CXPhone1.3.2.apk
and tell me if it meets your demands, also with your Android device and version.
Regards
vali
Vali_3CX
Thank you for new release!
This fixes the Volume Bug.
Unfortunately the new 1.3.2 version has new BUG!
I can not recieve the calls: sipgate to sipgate!
Sipgate is very popular VOIP Provider in DE and UK.
Please fix it so soon as posible :)
P.S. What does the new setting: "I am Out of Office" mean?
P.S.S. Can you also explain this settings: "Play Buffer", "Record Buffer".
When I making a call without recording it, is the "Record Buffer" acitve, should I also change it like "Play Buffer"?
Respect!
Any new builds of 1.3.2 version with sipgate fix?
Regards!
What sipgate fix? We do not make fixes for a VoIP Provider specifically.
Check better because we changed nothing in this area. We have no sipgate bugs. If there is a bug, it will affect all VoIP Providers and VoIP Providers work 100% with 3CX Phone for Android.
It means enable it when you are out of the office. When you want to connect to a remote entity. This will load the external server ip address (which has to change to Public Ip Address) and enable stun on.
These are options for recording. They buffer the audio in case there are delays whilst recording/playing to/from Harddisk. Ignore these options for now.
if there is no recording Record buffer and play buffer are not enabled because recording is not enabled.
Please try this
Regards
vali
Any difference between this version and Version on Market?
Is the Market release a newer build?
If you see update in market use that. If you do not see update in market then you have the latest.
Please update changelog and links on your site ;)
Can you tell us which ones have a problem? I will address them.
I have used only the versions 1.3.1. and 1.3.2 from your forum.
I did not tryed the Market version.
When I use 3CX phone for Android on a Samsung Galaxy S Plus (also known as the I9001) the microphone doesn't work.
Changed a lot of settings in the app and checked the mic settings, but it won't help. Speaker is working fine.
I tryed version 1.3.1 and 1.3.2. (after each call 1.3.2 is crashing also...)
Can somebody help me please?
We have made a lot of tests on this phone - It works very well. There must be something wrong.
How do you try to call? Do you have a tunnel connection, normal registration to a pbx, voip provider?
I think there is some intermediary version on your phone.
Delete all profiles you have just to be sure you do not take any corrupt configs.
Uninstall 3CX Phone for Android Completely.
Then go to the google market and download 3CX Phone for Android from there.
Try and create a connection and see if that works.
My Phone is Motorola Defy 2.2
Please fix the In-Call/Media Volume Bug.
Regards!
Re: NEW: 3CXPhone Phone for ANDROID 1.3.3
Great improvement now it will work over 3G
However, I can't get my head around the 'Office' / 'Home' toggle button.
What is it used for?
I've tried using the phone with both settings and there is no difference.
Motorola Xoom has been updated to 3.2 so now the app satys it is not compatible with the Xoom any longer.
It's generally used to switch quickly between network settings required for use outside the office (at home?) and, on the same LAN as the 3CX server. One can be set to use STUN, route to a URL rather than the local IP of 3CX, etc. I have found that it will usually work anywhere with the "outside the LAN" settings, but a lot can depend on the router you happen to be behind.
DejanMDS
