New Yealink Deskphones (T34W and T44U)
erectaat
Titanium Partner
Hello, will the new Yealink phones supported in 3CX V18 soon?
Reactions: Les Webb
Hi any update here as these phones have been out for some time now.
While not officially supported, I have used the T33 template for the T34W and it works great with no issues. Just an FYI.
Any chance you tested this as a router phone (SBC)
If there is some reason to be concerned the T44U will not eventually be supported a heads up would be appreciated. We have a customer that wants to use about 140 of them. They work with the 43 template so my thought is eventually this will be added. We did notice the backgrounds work with bmp on the 44 though and not the dob. Needs to be manually added through the phone though.
Yeah I would really appreciate some guidance on this. This has been a really odd situation. I don't really understand why we can't get an answer. It clearly works so I can't imagine it would be terribly difficult to officially support.
It is decided by 3CX, however, both ends are discussing this matter.
Oleg,
Has 3CX discussed much else on this? Are there any further updates on the T44U full functionality? Again for the others on the forum thread, so far the T43U Template has worked great, again just a reboot of the T44U Phones to take changes on button layouts
Hi everyone, we have an update regarding new Yealink models.
We are currently testing T31W / T34W / T44U / T44W to be included in V20 Update 3.
As for questions regarding V18, not further phones are being added since this version is reaching end of life.
Stay on the lookout for our next Alpha / Beta builds where you can also test these models if you have them already.
https://www.3cx.com/docs/phone-firmwares/
This is awesome new, thank you. I see new Yealink firmware for the Unified models was just released - are there any release notes or other documentation on the changes made? Yealink is not publishing the 3CX version change logs on their support site.
Stephan Eusebe
