Solved Office Hours for Call Queue
George Ts
Hello everyone,
Since we can only define office hours per PBX, SIP Trunk (Inbound Rules) or per extension, but not per Queue, I am trying to find an alternative approach to make this work for queues as well.
Here is my scenario:
1. Incoming call from a trunk
2. Call goes to Digital Receptionist. DTMF 3 triggers the call to go to the the Queue of the Accounting department
3. That department is there from 08.00-15.00, while the whole office is there from 09:00-17:00.
4. Now, we cannot define office hours for a queue. So, i thought of creating a "virtual" extension that has office hours from 08:00-15:00 and somehow routes the calls to the queue, depending on this virtual extension's status. More specifically, if the extension is available, calls go after 1 second to the Accounting call queue, if the extension is DND (out of office hours) calls go to the Queue's voicemail.
As simple as it may sound, this does not work.
First, we need a way to keep that extension appear as registered even if it does not exactly live on a 3cx client. One way I have found to do that, is by selecting "Ring My Mobile simultaneously". I have set its own number as the mobile and indeed, it appears as registered.
Second problem is that for some reason, it will just not go to DND when its office hours are over, even upon a 3cx server restart. Not sure if this might be related with the "Ring mobile simultaneously" setting.
Any suggestions?
Thank you in advance.
Actually, having the extension registered is NOT necessary.
In the forwarding rule of this extension you will need to have this rule populated:
During office hours the automatic switching will change the status to available and this routing will be used even if you do not have a device registered.
You can safely remove the Ring My Mobile Simultaneously option.
So during your office hours of 0800 - 1500 the call will go to accounting
For the DND profile:
All the agents in the Accounting Queue will receive an email with the voicemail as an attachment.
Do not keep this extension registered. It is unnecessary.
Also, do not forget to go to the forwarding rules and enable the Auto switching and define the office hours from here. Then it will switch the extension's status automatically.
It actually works. Thank you for your excellent support @NicholasP_3CX !
Reactions: NicholasP_3CX
EMMEPICASA
