Open URL on incoming call PWA Client v18
duxi
Dear Community,
I've setup to open a URL of a CRM where it's not possible to filter for phone numbers over the API yet, it' just a basic URL search with query strings when answering a call.
This works fine for direct calls and blind transfer but I've got a problem with attended transfer:
Whenever the call gets transferred the variable %CallerNumber% contains the internal number of the employee and triggers the URL with it instead of the external callers number.
Is there a way to access the original caller number as variable somehow?
I would be thankful for any help
Hi @duxi,
How is the transfer happening? I'm assuming it's an attended transfer? If so, there isn't much we can do since an attended transfer is like a new call entirely.
Hi @VasilisV_3CX ,
yes it's only with attended transfer, blind ones are fine.
So there is no option to provide the original number, would it work if the CRM has a API? Then I have to wait for it.
Reactions: Frank Brice
Hi @duxi,
Yes, a bit of patience in this case. I'll close this thread and if you need anything else, feel free to open a new thread.
