outbound call problem
velentos
when i try to make call i get this message from provider
Call or Registration to 2531083800@(Ln.10003@ote) has failed. 195.167.16.28 replied: 403 Forbidden; warning: Invalid User; from IP:195.167.16.28:5060
what changes i have to do to make it work
thanks in advance
register based trunk it register ok and i have inbound but on outbound want modification in parameters
Hi ,
Do you have created an outbound rule? what's inside?
Your sip trunk is allowed to outbound calls?
11266
yes they re the inbound work fine the outbound want modification in parameters and i dont what is the modification
Can you share a screen copy of your outbound rule?
its not problem of outbound rule the provider need change in outbound parameters of the trunkbut the support of ote is dump
If it was an outbound rule issue, then most likely the response would come back from the IP address of the PBX not the provider IP:
The only time the outbound rule would be considered would be if the response was being sent back from the provider because of what has been sent from the outbound rule (digit manipulation for example).
Again as above take a Wireshark capture and lets see whats being sent in the INVITE that the provider does not like.
Hello @velentos
The user in the following thread has an issue with OTE and managed to resolve it. He also mentions that he had to make a few changes in the outbound parameters to get everything working. Unfortunately he does not mention what those changes were. Perhaps you could send him a p.m. and ask for the changes. https://www.3cx.com/community/threads/sip-trunk-registration.51083/
i did it but he has to register over 3 months by the way ia had found solution
thanks all for your assistance
anyone wants help about it pm me
any way how we can add templates from greek providers?
To include a providers template into the PBX, the provider must be willing to work with us so we test their service and create a working template. So far we haven't had interest from any Greek providers.
Now that you have a working setup of OTE however you can export the template and use it on other systems
how a provider can come in touch ??
fcentral
