Outbound calls
Veekash
New User
If i buy the pro licence for 3cx am i limited in the amount of outbound calls i can make .Do i have to pay a certain amount for a certain amount of outbound calls .Is there a way for me to call unlimited amount of times using the pro licence
With the 3cx SMB, you are limited to the number of extensions you can have but not the number of sim calls.
Although outbound calls are limited to the number of calls you can send through your chosen sip trunk, within 3CX SMB and 3CX Free, Sip trunk settings allow up to 10 calls, made up of both inbound and outbound.
So if i get the pro or enterprise license i am not limited ?
Your be limited by the amount of sim calls the 3CX subscription is for and the amount of sim calls you have with your Sip trunk provider, otherwise with 3cx hosted (Dedicated instances) you can amend the max allowed calls through the trunk settings, which can not be adjusted with 3CX SMB instances.
x1515
