Paging rings phone instead of instant pickup
advantec
3cx V20 Update 9
Yealink T85w firmware 185.87.0.37
Yealink T31p firmware 124.87.0.20
Using custom templates to allow for multicast
Paging is enabled for *9 and does dial the extension but it rings instead of instant pickup after tone. I can do a paging group to single extension and it does instant pickup and work like normal. But we have 35 classrooms and adding a paging for each individual is a chore and if more are added it will add to the task list. Is there somewhere in the settings or in the template to make this change? The template is a copy of the existing 3cx on with changes added to allow for multicast and multicast blf's
Hi Advantec, this is a permission thing.
Check the from extension and change it from User to Receptionist, or adjust its permission under "view" to include "call operations"
Carlos - EC Mates
