Partner Account / how to create standard license
Thorsten-0049
I want to create a standard license within the partner account website. I click on "Keys" and then on "Create Try License". I fill out the form but I always get a professional lincense. What's going wrong here, please?
Best regards, Thorsten
You will always get a Pro license as a trial license, after 40 days the license will revert to a standard license.
This is so you can use the Pro license features in the trial and see if you require them
3CX comparison chart -
https://www.3cx.com/ordering/pricing/
If you require the Pro features you can use the trial period and then upgrade otherwise you will drop to 8SC Standard
[email protected].
