Presence
hellascom
We have on my installation BRIDGE over tunnel this working correctly, on Presence we have enabled " Publish Information " with selected group and on Receive Information add remote FQDN same setup have and on other site of bridge but on 3CX Panel not showed the remote information of presece why wrong ?
Mostly this means that there is connectivity or DNS issue.
Can you please try instead of the FQDN's to use the public ip's for the bridge?
I trying to add IP address and shown below message " Enter a valid domain address, including a port if required "
Which https port you are using?
I use only FQDN now and not show any error but no working.
When try to add before FQDN https:// or http:// show same message.
When trying to change the IP, it is also the same.
You are using https port 5001 or 443?
443
Just to clarify the bridge is connected but only presence is not working?
The bridge working correctly
The presence not working.
Both PBX are in the same version and build?
Yes, last 20.0.2.708
Is there any error in the event log?
No error
If you disable the tunnel connection the issue remain?
The presence no working.
Can you please create a support ticket so we can further?
Now on event log show this error
Registration at My Bridge has failed. Destination (sip:127.0.0.1:5080;lr) is not reachable, DNS error resolving FQDN, or service is not available.
This seems to be related with your DNS.
Are you using the Google DNS as primary for both installations?
Allready created ticket 2072050
Close this thread.
Carlos - EC Mates
