Prioritized Hunt Ring Group Setup - How to ring multiple extensions at once?
tmeahl
Using On-Premise Enterprise v18 Update 8
Is it possible to setup Prioritized Hunt so if the first person is busy, it then does a "Ring All" to multiple other extensions at once?
For example the attached image we'd like all 3 cordless phones to ring at once
Thanks!
The easiest would be a skill-based queue. Set the first ring to skill 1, and the cordless to skill 2. Configure the ring time and max wait time accordingly.
@tmeahl You can also use two ring groups, where RG1 "no answer" calls RG2.
Reactions: KLIN and Evolute IT
ARKC
