Provision RPS Yealink W53P?
ElementalWindX
Is there a way to auto provision a Yealink W53P on a W60B base station via RPS/STUN in v16?
I'm trying and it appears the base station has picked up the information, but the account inside the headset is stuck in "Registering" status.
Inside 3CX I chose the "T53W" model when setting up the phone in the PBX.
Cannot see w53p on supported list but you should be able to configure using the setup for the other Yealink dect phones
For Yealink dect handsets you do not add a phone model under provisioning - delete the setup you have done for t53w
follow the steps for provisiong the base unit
https://www.3cx.com/sip-phones/manually-provision-yealink-dect/
https://www.3cx.com/sip-phones/yealink-dect-w52p/
note : you have to enter the provisioning link into the base unit web frontend - step 2 https://www.3cx.com/sip-phones/manually-provision-yealink-dect/
Got it to work. Forgot completely about the FXS/DECT section. Added the base mac addr to that, then went into the web portal and added the provisioning URL, hit auto provision, and it picked it right up and worked. I guess cause I added the mac under the phones section, it set it in the RPS and screwed up RPS after I redid it under FXS/DECT so it didn't pick it up from the RPS server automatically no matter how many factor resets or reboots I did.
Wecare_ITA
