Ransomware v15.0 Restore
clawton
Hi all,
We have a customer who was hacked recently and had an old 15.0 PBX. The only backup was from the initial install we did back in 2021. I've tried to restore this to a 15.5 version but that throws an error about being unable to contact the 3cx license server. v16 and higher systems won't accept the backup as they require 15.5.
Are there any other options we can try to get a system back online? Customer is happy to upgrade to v18 etc but is desperate to avoid any further downtime or having to rebuild the system. They are far from us and we will need to arrange a site visit.
Thanks in advance.
Brian
You'll need to contact 3CX Support.
We are a partner but only entitled to use the forums, we don't ship many licenses.
Sounds to me like you have little choices, based on no backups. 3CX Support may not be able to help much other than renewing the license.
Hi, @clawton
Depending on what is the current version of the backup and the status of the license maintenance, there may be an option to consider the backup conversion assistance that can be provided in some cases.
It is a paid service and it is provided only to registered 3CX partners.
If you would like to check this option, please email us at [email protected], include the license key number that is currently included in the backup, and we will provide you with further details to consider and discuss with your customer
Best regards,
Irina
Reactions: N_G and Evolute IT
I don't think being on-site is necessary, but the situation looks like there could be multiple issues that might confuse attempts to get upright. Especially in a compromised LAN with legacy systems. You might consider moving them to something like Digital Ocean or finding a cloud hosting partner like ourselves (DSXVOICE) so you can get the PBX itself out of the mix and upright as quickly as possible.
sherry reynolds
