Record DR Prompt
jcostlow
Gold Partner
We have had more users want a way to record/change the DR prompt via telephone instead of management console since they used that on previous systems.
I am trying to build a basic CFD that present them with option 1 to return to the usual prompt. Pressing 2 records a new prompt and am trying to use set DN to change the prompt. Would that be a global prompt or is that even an option?
I have a similar project at the moment, I currently have the recording saving to file that will over right the existing .wav file used in the IVR. I was hoping this would seamlessly update the prompt (need to test this out), but if not this could be an option.
Simply replacing the recording file will not work. 3CX caches the recording with the IVR. You will need to give the prompt a new file name and update the IVR configuration to use the new recording.
We did something similar years ago for a job line. The customer wanted to provide a way to update a recorded list of available jobs, without giving access to the 3CX administrative console. If you would like to try our solution, contact me.
DejanMDS
