Recordings Permission
KarstenWeidinger
We have to grant the access to download the call recordings for multiple users.
But if we enable the option like above, it will grant them also access to alter the "Recording Quota Options", what is of course not wanted.
What is the supposed way to achieve this? Access the call recordings, but not the quota settings.
Best regards
Karsten
Hi Karsten,
You can give access to recordings without giving access to the management console like this :
On management console > phone provisioning > select "3CX App" > scroll down to "Access" > tick "Show call recordings"
On web extension you will be able to download recordings here :
But it will show the own recordings only, right?
Not the recordings of colleagues, which is needed.
In "recordings" from the webclient/desktop app, you will be able to classify by "All recordings" and "My recordings".
Reactions: KarstenWeidinger
Also in the "rights" of the extension, tick "Can see group recordings (Available in Professional and Enterprise)"
In this way, you will be able to see from "all recordings" tab (desktop app/webclient > recordings) recordings of your group.
If you want to see recordings from another group, you will have to add your extension in a different group here :
Thank you very much!
I just found the second (most important) part myself!
/resolved
mazet
