Solved Repeating emails
jpeppas
I have a on premise installation (v.18 update 8) and also an external SMTP. I am sometimes getting multiple (maybe hundreds) of email alerts for the same alert.
Αny idea why this may be happening?
Thanks,
Jim
What notifications are you receiving?
Have you ensured that only from this PBX or the email is not configured to another installation?
one installation only..
the alerts are for missed calls in queues "There was a lost Call in Queue Sales (xxxx) from Caller ID +xxxxxxx"
This means that your extension is also a manager of the Queue and you have enabled the option to be notified for Queue lost calls:
Yes, of course, how else would I be getting notifications. That isn't the issue, the issue is that I am getting 100's of notifications for the same alert. I had to disable and re-enable the notifications for it to stop..
I have the system for a few years without any issues. Problems started when I upgraded to V18 Update 8, could not connect to the 3CX mail system and had to connect to a 3rd party SMTP. Mails worked ok for some time, then this happened.. After disabling/enabling the notifications, the problem disappeared, however, I haven't got down to the root cause.
Maybe a failed email delivery caused this issue however you need to check the logs to identify this.
I guess we should close this thread, since I don't have enough information on what happened.. Thanks for the feedback.
You are welcome ;)
cur_cb
