Ring group and Queue only rings one person
MartinAndel
I have a new SMB free instance with five users. I tried creating both a ring group and a queue, no IVR's just straight ring all. But it only rings the system owner extension however and when that is busy, the calls go straight to their voicemail. What am I doing wrong? I have added all five users before you ask :)
I noticed both the RG and Q when being created automatically assume an extension outside the free 10 numbers allocated range and when I tried giving it one of the spare extension numbers from within the range it does not like it.
How is your routing? You need to assign a did to the ring group.
I did that in the general settings, yeah.
Ok, and if you call this number the call is going the standard route to the system owner? Did you configured your trunk correctly? What provider?
Ah, a classic rookie mistake :) I had it routing to a user instead of the ring group. Thanks for your help!
Reactions: bitn2
Hassan Murasan
