- Joined
- Jul 30, 2018
- Messages
- 314
- Reaction score
- 74
We have an SBC that every 2 or 3 minutes the UDP status goes down:
The calls are not normally affected but 2/3 times a day the calls are actually dropping and causing 1-2 minutes downtime.
The customer is running a fibre leased line and the line is steady, and there is no packet loss. I verified this by running a ping to the phone system for 24 hours.
The UDP NAT timeout on the dreytek firewall is set to 1800s.
The Raspberry PI has been swapped.
Any Ideas?
| Build Version | 16.0.386 |
| Agents Behind SBC | 0 |
| Calls Behind SBC | 0 |
| TCP Encrypted | No |
| TCP Packets Received/Sent | 2/0 |
| UDP Status | DOWN |
| UDP Encrypted | No |
| UDP Packets Received/Sent | 0/0 |
| UDP Ping | - ms |
| Operating System | Raspbian |
| System CPU Usage | % |
| System Memory Usage | % |
| SBC Memory Usage | % |
| Disk Usage | % |
| Bandwidth used from PBX (Rx) | - |
| Bandwidth used to PBX (Tx) | - |
Any Ideas?
