SBC Register but Phone fail to register
Alex Aubert
Gold Partner
Hi I got a strange issues where Router Phones are able to register and SBC register as well but the Normal phones are unable to register to the SBC on both router phone or Debian.
I did try to activate verbose logs on debian config file. /etc/3cxsbc.conf but when I restart the services the config file is repulled from the 3cx so I lose my change.
I did try to reinstall the SBC and the issues still the same
  1. Disable account 1 on the Yealink and save.
  2. Start pcap on Yealink (Settings>Configuration>PCAP)
  3. Enable Account 1 and save
  4. After 30-40 sec. go stop the pcap and download it
When opened in wireshark you should see the phone source IP send REGISTER to destination of the SBC IP at port 5060.
Does it send it and does it get an answer back?
I did restart the service : using this command
sudo systemctl restart 3cxsbc
I see from a phone pcap that my SBC doesnt reply
Ok finally, you should also look up how to run tshark on your SBC and then restart the phone.
After the phone is up for a minute at least after startup, you can stop the tshark capture.
So now you are looking for the opposite, see if the REGISTER sent from the phone ever reached the SBC, and whether the SBC actually replied back but the phone never got it.
Bash:
apt install tshark
tshark -i any -w capture.pcap
dont receive anything from the phone but if I ping this is replying
You’ll need to check the network configuration, as per the response in your existing ticket with 3CX Technical Support.
Please note that ping uses the ICMP protocol, which differs from how phones communicate using SIP on port 5060 over UDP. A successful ping does not guarantee that SIP traffic is allowed or correctly routed, so we recommend verifying that UDP port 5060 is open and not being blocked or filtered on the network or firewall.
  • Love
Reactions: JohnS_3CX
On CBS220 - This option that block phone registration
Go to the "Security" section, then "Denial of Service Prevention," and finally "DDOS Security Suite."
2025-07-18 13_12_39-PF-VIC-HV01 - ScreenConnect - Connected.png​
KylieWilderman
