Scheduled Reset Statistics of the Queue does not work
mastermindjf
How to solve this problem?
Manual reset OK.
Thanks in advance!
Hi @carlos@mastermindsupport.
I've tested this and it works perfectly. It resets the statistics in the Switchboard as intended both manually and with a timer set. Is there perhaps any other place that you may be anticipating the statistics to be reset?
Have you checked that the system time is correct? Check under Settings >> Timezone, Office Hours & Holidays >> Timezone.
Make sure timezone, time and (if not installed from debian ISO or running on Win) NTP installed.
Funny we detected the same problem today in a customer of 14 queues 2 do not reset the statistics automatically being necessary to make manual.
Was the PBX shut down during that time perhaps? Or do you have scheduled Windows updates (if Windows server) that may have shut down the 3CX services during maintenance?
We have had cases where this prevented the statistics from being reset because the services were not running during the scheduled time of reset.
Linux server.
Backup scheduled at the same time as the statistics reset, but only 2 of the 14 queues do not work automatically.
Is the PBX running inside a VM, and what hypervisor are you using in this case?
In this case may I suggest you contact 3CX Support and open a case?
We can look into it further via Support and see anything appears in the machine logs.
Reactions: ChrisC_3CX
VasilisV_3CX
The timezone is correct. The PBX is running on Linux Debian VMACHINE. Manual reset works.
3CX have a activity log of this?
Some VM's that have time critical tasks don't like to have their clock managed by the host.
If this is switched on it might be worth toggling it off to see if it helps.
Reactions: mastermindjf
florentrobineau
