Separate Backup from Recording Storage
lancerichards
Platinum Partner
Hi Team,
We have a scenario where a customer would like to have the storage of their recordings on their Sharepoint with M365, but as part of our standard practice, we push our daily backups for customer managed instances to a SFTP server.
The only way I can see I'll be able to do this with Sharepoint configured is to run a bash script to do the backup to the secondary location of SFTP.
Does anyone have any better ideas?
Best,
Lance
Sounds like you've already thought of the answer tbh
Yeah, I did spend a bit of time thinking about different solutions @Alphabetic :)
Sometimes, it's best to cast the net a bit wider to the greater brains trust to see if anyone has a better idea.
The collective brain is often greater than the single one :)
costionofrei
