Separate extension for branches
Networkbug
Need little help with extensions
HQ-101- Can reach all branches ( A & B)
Branch A-201 cannot contact Branch B-301 vice-versa but both can contact HQ.
Is there a group permission I have to apply?
Using 3CX V18 on Windows 10 pro 64bit
Thanks,
Extensions should be able dial (reach) all other extensions on the same PBX. Are they all on the same PBX, or are you using Bridge trunks?
Have you checked he 3CX Activity Log, to see why the calls are not going through? You may need to set the logging level to Verbose.
Sorry for not adding more information. I meant to block the extension from calling each other but both branches should be able to talk with HQ. Branch A and B should not be able to view or communicate with each other.
The group permissions will prevent some things being visible, but will not prevent extensions calling each other.
Normally you cannot block the dialing of other extensions on the same PBX, however, see the example on using forwarding, in this thread...
https://www.3cx.com/community/threads/prevent-calling-to-an-extension.76864/
If the sets are the type with an internal dial plan, you may be able to block certain ranges from being dialed, at the set.
Reactions: Networkbug
Thanks for this, The only way I can remove from directory is by adding them to different group which is not visible to user but the extension is reachable.
@Networkbug
See the new capabilities of the new sp4 multi-company mode https://www.3cx.com/blog/releases/v18-update-4/, be sure to test it before tying it in production. Additionally, there are management capabilities in this mode https://www.3cx.com/blog/releases/startup-call-handling/, and these are accessible to users that are set with manager rights, as well as the powerful receptionist views.
Hello.. Thanks for suggestion, I tried to update my version and got this error - I cannot restart the update.
martin1176
