Separate inbound rules for each queue !
Rida
Hi members,
Is possible to create separate inbound rules for each queue with different DID 's ?
Thanks for replay!
Why explain more, and what you are trying to do.
As you have DDI numbers, you can route calls to to your requirements
I want to block callers who call anonymously for one queue, and let other queues pass through.
Thanks everyone, i will try it !
Perhaps if your sip provider give you access to an avanced console you can set this before reaching 3cx.
If so then anonymous calls are dropped from sip provider.
Reactions: Rida
Create a new user.
Go to the Forwarding Rules tab.
Route it (Available) when not registered to your Queue.
Make an exception at the botton with caller ID anonymous and route it to End Call.
abctel2
